P: Scott Spark 60 L 2011
OdgovorNapisal/-a cresh » 11 Sep 2017 19:56
Prodam XC fully bajk Spark 60, je letnik 2011, res redno servisiran in na kolesu vse štima, nikjer nobenga lufta, podvozje brezhibno.
Gor so skoraj novi gripi ODI (2xfurani), pedala Saint, plašči HR in Ardent še lepo ohranjeni.
Prodajam zgolj zato, ker grem na AM bajk
Specs:
Frame & Fork
Frame Construction Alloy
Frame Tubing Material 6061 Alloy Double Butted
Fork Brand & Model RockShox Recon Silver RL, 120mm travel
Fork Material Unspecified
Rear Shock DT Swiss M210, 110mm travel
Components
Component Group Mountain Mix
Brakeset Shimano BR-M445 brakes, Shimano BL-M445 levers
Shift Levers Shimano Deore Rapidfire
Front Derailleur Shimano Deore, clamp on 34.9mm
Rear Derailleur Shimano SLX
Crankset Shimano Deore, 44/32/22t teeth
Bottom Bracket Shimano Cartridge
BB Shell Width 68mm
Rear Cogs 11 - 32 teeth
Chain Shimano CN-HG53
Seatpost Scott Comp, 31.6mm diameter
Saddle Scott Racing
Handlebar Scott Pilot 15 Team
Handlebar Extensions Not included
Handlebar Stem Scott Racing
Headset 1 1/8" Ritchey OE
Wheels
Hubs Front: Scott Team Disc CL, Rear: Shimano FH-RM 65
Rims Alex XC-44 disc, 32-hole
Cena: 650€ ni zadnja.
kontakt: 041/555-502
http://www.bajk.si/kolesa/gorska-kolesa ... 2011_i7390
cresh
Prispevkov: 20
Pridružen: 22 Sep 2016 20:23
Uporabniki, ki brskajo po tem forumu: kr3ature, orun, Yahoo [Bot]
