Lapierre Edge AM 527
OdgovorNapisal/-a blazcof » 08 Nov 2017 19:04
Prodam kolo Lapierre Edge AM 527
Velikost: L
Letnik: julij 2017 (je še v garanciji do 7/2018)
Frame NEW EDGE AM 27.5’’ ALLOY SUPREME 5 OST+ 140mm Rear Travel
Fork ROCKSHOX SEKTOR SILVER RL 27.5’’ SOLO AIR 140mm 15QR
Shock Absorber LAPIERRE AF-2 HYDRAULIC DAMPING TECHNOLOGY 200x51mm
Headset FSA ORBIT 1.5E ZS NO.57E + 8mm Top Cap
Bottom bracket Livré avec le pédalier / Included with crankset
Crankset SHIMANO DEORE FCM617CB62L 36x22 170mm (S) / 175mm (M, L, XL)
Stem LAPIERRE AS-M05 Alu 6061 Ø: 31.8mm L: 55mm
Seatpost LAPIERRE YSP-12L DROPPER POST Ø: 31.6mm Travel: 125mm
Handlebar LAPIERRE Nico Vouilloz Signature Alu 6061 W: 760mm R: 15mm Ø: 31.8mm
Front derailleurS RAM X7 S3 36 DUAL PULL E-TYPE
Rear derailleur SHIMANO XT RDM786GSL 10-Speed
Brakes SHIMANO HYDRAULIC BRM396 BLACK - SHIMANO ASMRT56 180mm / 180mm 6 Bolt Type
Shifters SHIMANO DEORE SLM610 2x10-Speed
Saddle LAPIERRE VL-1353 BY VELO
Wheel MACH1 KLIXX 27.5’’x23C 32H - FORMULA DC51 15QR 32H - FORMULA DHT142 32H BLACK 12x142mm + LAQR-12-E Thru Axle
Sprocket SHIMANO DEORE CSHG5010136 11x36 10-Speed
Tires SCHWALBE TOUGH TOM K-GUARD 27.5x2.35 (Front) / 27.5x2.25 (Rear)
Info: 040568508
Priponke
blazcof
Prispevkov: 1
Pridružen: 08 Nov 2017 18:21
Uporabniki, ki brskajo po tem forumu: kanta, pogo, sportiva, tadej3453, Yahoo [Bot]
