Giant Reign 2 LTD, 2015, velikost XL
OdgovorNapisal/-a buda_7 » 14 Nov 2017 11:14
Prodam 3 sezone rabljeno enduro kolo Giant Reign 2 LTD (letnik 2015) v velikosti XL.
Posebnosti:
- kolo je predelano na 1x10 pogon
- vzmetenje poservisirano v začetku letošnje sezone
- pred 12 turami menjana veriga in sprednji zobnik
- na slikah so SRAM Guide zavore, ki jih bodo ob prodaji zamenjale original Shimano Deore
Velikost XL
Barva Charcoal
Okvir ALUXX SL-Grade Aluminum, 6.3"/160mm Maestro Suspension
Vilice RockShox Pike RC Solo Air, 160mm travel, 15mm Thru-Axle Giant Custom 46mm Offset
Amortizer RockShox Monarch DebonAir RT
Krmilo Giant Contact SL DH, 800mm, 31.8
Opora krmila Truvativ Holzfeller (60mm)
Opora sedeža Rockshox Reverb Stealth, 30.9, 125mm
Sedež Charge Spoon
Pedala Superstar Components Nano X
Prestavna ročica Shimano Deore
Zadnji menjalnik Shimano SLX, Shadow+
Zavore Shimano Deore [F] 203mm [R] 180mm
Zavorne ročice Shimano Deore
Verižnik Sunrace MS3 11-42
Veriga SRAM
Gonilke z verižniki Shimano Deore, Superstar Components Narrow Wide 30t
Bottom Bracket Shimano Press Fit
Obroči Giant P-AM2
Pesta [F] Giant Tracker w/ 15mm Axle, [R] / Shimano SLX, 142x12mm DT Swiss RWS Thru-Axle, 32h
Napere Sapim Race, double-butted, black
Plašči Continental Der Baron Protection Apex 27,5x2,40 (tubeless)
Več info na budko_7(afna)hotmail.com ali 0štiri0 2dva6 2pet7. Ogled in prevzem na Gorenjskem.
Slike na:
http://www.bolha.com/rekreacija-sport/kolesarstvo/kolesa/gorska-kolesa/giant-reign-2-ltd-2015-velikost-xl-1330286050.html
buda_7
Prispevkov: 6
Pridružen: 27 Jun 2013 14:20
Uporabniki, ki brskajo po tem forumu: Bing [Bot], Google [Bot], hanataja, ninot, OPTIBIKE, tadej3453, THE čudn, Tumci, wreck
