P: Zadji amortizer DT Swiss M212 Remote - Nov 99 EUR
OdgovorNapisal/-a mobiking » 13 Feb 2018 14:36
Nov še nikoli montiran zadnji blažilnik - amortizer za gorsko MTB kolo.
DT Swiss M212 Remote 190x50mm.
Zaklepanje z ultra light ročico na krmilu.
Specifications:
Make: DT Swiss
Model: M212 Remote Rear Shock
Weight: 198g
Eye to Eye x travel mm: 190mm x 50mm
Air chamber finish: Aluminium black anodized
Spring system: ABS
Damping system: Lightweight hydraulic damping circuit, internally set compression
Adjustment: Open, Climb-Lockout mode, adjustable rebound
Remote: Yes
Mounting system: Ball joint, reducers
Lahko pošljem ali dostavim.
GSM: 041-31-31-31
Cena 99 EUR.
mobiking
Prispevkov: 136
Pridružen: 14 Avg 2011 01:09
Uporabniki, ki brskajo po tem forumu: blazs, cicibanst, Google [Bot], no_name, orun
