P: Santa Cruz Nomad Carbon 2013
OdgovorNapisal/-a Urkisimo » 09 Maj 2018 18:12
Prodam kolo Santa Cruz Nomad Carbon, velikost XL, top komponente, letnik 2013, redno servisirano, 1. lastnik, veliko dodatnih delov.
Oprema:
Frame: Full carbon frame and swingarm, VPP® suspension, 142×12 rear axle, 160mm travel, Threaded Bottom Bracket, ISCG05 mount
Fork: RockShox Pike RCT3 Solo Air 26" 160 mm
Shock: Fox Float CTD Boost Valve Trail Adjust Kashima Coated
Rear Derailleur: Shimano XTR Shadow+, ONE UP kletka
Shifters: Shimano XTR I-Spec
Crankset: Shimano XTR 1x10 z RaceFace NW 30T zobnikom
Cassette: Shimano XTR 11-42 - ONE UP
Chain: Shimano XTR
Bottom Bracket: Shimano XTR
Brakes: Shimano XTR Trail (BR-M985, BL-M988)
Brake Rotors: Shimano SM-RT86 Ice Tech (200mm spredaj, 180mm zadaj)
Headset: Cane Creek 110 series
Bars: Thomson Allmountain Carbon 31,8 x 730
Stem : Thomson Elite 4x
Grips: Crank Brothers Lock On Cobalt
Wheelset: Syntace W35 MX 26"
Front Tire: Onza IBEX 26x2.4
Rear Tire: Onza IBEX 26x2.4
Seat Post: Thomson Elite
Saddle: ERGON SM3 Pro Large
Weight: 11,99 kg (brez pedal)
Dodatno priložim:
- novo verigo (Shimano XTR)
- nov gonilni ležaj (Shimano XTR)
- nov set zavornih oblog
- nov set original ležajev za okvir
- Santa Cruz grease gun
- vse potrebno za predelavo na 2X10 (prednji menjalnik, ročka, zobniki, bovden, pletenica)
Lahko tudi v kombinaciji s Cane Creek Double Barrel Air CS.
Kolo je raketa in se tako tudi pelje.
Slike na Bolhi: http://www.bolha.com/rekreacija-sport/k ... 63521.html
Cena: 1900€
Uroš, 031-746-248
Urkisimo
Prispevkov: 15
Pridružen: 20 Avg 2012 19:52
Uporabniki, ki brskajo po tem forumu: Brundi, dani, flaša, mastif, wilecoyote
